Product Details
Wiki & Learn
Reviews
Download PDF
Feature
⚠️Buying Guide
This is a fully assembled version, ready to use out of the box. Items pre-selected are essential for smooth robotic arm operation. If you'd like to explore teleoperation, please purchase the "Star Arm 102 (Leader Arm)" and "12V 2A AC/DC Adapter (5-in-1)" together. A mounting G-clamp is required to securely fix the robotic arm to a workbench. Please make sure to include one if you do not already have it. All other accessories are optional and can be purchased as needed.
  • Plug-and-play bundle: Assembled robot arm kit plus NVIDIA® Jetson AGX Thor™ Developer Kit, allowing on-site VLA model deployment such as GR00T, PI, OpenVLA etc.
  • Fully Open-Source: 100% open-source robotic arm, certified with CERN-OHL-W 2.0, in terms of both hardware and software. It includes the BOM list, hardware drawings, software, and algorithms, everything you need.
  • Detailed Assembly Tutorials: Provides extremely detailed illustrated and video assembly tutorials, wiring instructions, calibration procedures, and environment deployment tutorials, lowering the entry barrier for robot development.
  • High-performance motors: The reBot Arm B601-RS uses 4pcs RS-00 motors and 3pcs RS-06 high-torque, low-noise high-performance motors, providing the robotic arm with stable and precise power output..
  • Framework Compatibility: Supports mainstream robotics development frameworks such as ROS1/2, NVIDIA Isaac Sim, Hugging Face LeRobot, Pinocchio, etc.
  • Constant Content Updates: As the project progresses, we will gradually update the latest trending algorithms and launch a series of completely free tutorials.
Degrees of Freedom6+1
Reach587.5mm-754.7mm(without gripper)
Payload2.5kg (Rated load)-5kg(Maximum load)
Repeatability0.1 mm
Weight6.7kg
ServosROBSTRIDE 06*3 & ROBSTRIDE 00*4
Operating Temperature-20°~50°
PowerDC 48V 15A
ROS1✅
Moveit1✅
ROS2✅
Moveit2✅
Python✅
Lerobot✅
Isaac Sim✅
Pinocchio✅
Open Source✅
Hardware Overview
Application
Sim-to-Real learning course
Seeed Studio collaborates with NVIDIA to introduce a new hands-on curriculum for developers: from robot demonstrations and simulation to VLA post-training and real-world deployment.  This course guides learners through hardware setup, data collection, model training, simulation validation, and finally deployment and inference on reBot ARM B601-RS and NVIDIA® Jetson AGX Thor™.
Learn & Build Robotics Easily
Lower the barrier to robotics with step-by-step tutorials. The reBot Arm B601-RS helps you go from assembly to intelligent robot control quickly and confidently.
Research & Laboratory Automation
High-precision robotics for liquid handling, sample transfer, and laboratory workflows. Built for repeatability, delicacy, and rapid experimentation.
Teleoperation & Physical AI
Power real-time control, data collection, and sim-to-real learning with leading robotics frameworks including LeRobot and Isaac Sim. A dexterous “hand” for embodied AI.
Industrial Automation & Logistics
±0.1 mm precision, up to 5 kg payload. The reBot Arm B601-RS enables precision assembly, inspection, sorting, and material handling in manufacturing and warehouse environments. Compact and easy to integrate into existing production lines and workcells.
Your Physical AI Project Deserves the Spotlight!
Seeed Studio's monthly "Physical AI Project of the Month" is now open for submissions—whether you're building with the reBot Arm (B601-DM/RS) or the SO-ARM (100/101), this is your chance to showcase your work to the global robotics community and get featured by Seeed Studio!
Join our Discord community for discussions and support:
https://discord.gg/wsfpnbm3cU
Assembled Robotic Arm (with gripper)1
RobStride USB-CAN Driver Board1
CANABLE1
XT30 2+2 Power Separation Board1
Hex key wrench set1
Mouse pad1
Wire kits1
Power Adapter for reBot Arm B601-RS1
NVIDIA® Jetson AGX Thor™ Developer Kit1
reBot Arm B601-RS Bundle with Jetson Thor
SKU E26062402
The reBot Arm B601-RS is a truly open-source robotic arm for Embodied AI. Featuring a 2.5 kg payload, 767 mm reach, and ±0.1 mm repeatability, it lowers the barrier to sim-to-real robotics development.
Bundled with NVIDIA Jetson AGX Thor (2070 TFLOPS), this all-in-one kit delivers robust edge computing to run mainstream VLA models like GR00T and PI, a complete one-stop platform for real-world physical AI deployment. Curriculum available for step-by-step instructions of sim-to-real VLA pipeline based on this bundle.
Robot Arm
Assembly
AI Computing Platform
Kit Type
USD$7377.00
reBot Arm B601-RS (without power supply)x1$1799.00
NVIDIA® Jetson AGX Thor™ Developer Kit (945-14070-0080-000)x1$5499.00
Power Adapter Kit for reBot Arm B601-RSx1$79.00
